I thought one of my rear tail light clusters was leaking, but after resealing it twice I found water seems to be coming above the cluster and running down into it on the inside of the boot, so the cause seems to be the boot seal.
Is it typically the seal between the rubber and the bootlid that is the problem, or can water seep in underneath the seal where it is pushed onto the boot? First task is to put some vaseline around the boot rubber to get a better seal. Is there any other products that would be better/less messy?
Thanks,
Kevin
Boot seal leak repair question
Pull the seal off, and you may find a rust hole right through underneath it.
kevin316i
Thanks Brian,
I thought that might be a possibility, but was in denial
I'll remove and see if there is any holes. Feeling around inside isn't indicating any, unless it's up high on the seal lip.
kevin316i
Just took a closer look and found a little rust spot on the inside just above the tail light.
