Cabby 1/4 window conversion?
Greeny
Post Tue Jan 09, 2007 2:02 am
Hi Guys. Does anyone know if it is possible (or if it's been done before) to remove the front quarterlight windows from the convertible or is it simply too much work. I'm pretty good with a welder and don't mind a challenge but if it really is a nightmare then i'll forget it. Just can't get the idea out of my head, I think it would look mint.
Cheers!
Gone but not forgotten.
('92 325i Cabriolet)
johnna
E30Zone Irregular
Post Tue Jan 09, 2007 8:29 am
They are there to strengthen the shell. I'd not want them removed...
Be a man for once in your life and sh!t in that boot!- Wilfred.
Rosc0PColtrane
Post Tue Jan 09, 2007 8:33 am
Also provide some protection from wind when roof and windows are down.
Ziggy
Post Tue Jan 09, 2007 9:16 am
It's the protection from tarmac in the event that the car's upside down that I'd be worried about. Would look good though! :eek:
mrLEE30
Post Tue Jan 09, 2007 3:42 pm
would look good but i reckon you would have sealing issues, i doubt the cab door is the same as a coupe door internally, so i doubt the window lifter mechanism would fit to enable you to put a coupe glass in there... and as for roll over protection.... i doubt seriously they would do much in a serious roll, i have read that even the reason the cab seats dont recline is to help in roll over protection so you are trusting your head to a head rest as much as that little bit of glass/frame and if you happen to be chillin in the back when you go over..well thats another matter.
as for the idea go and grab a knackered rusty 2 door door and try and fit it..if it fits cut off the top and rear window surround.. if that works lets see a pic!!!
and a little bit of useless info.... that little 2-3inch wing normally situated just in front of a F1 drivers steering wheel is the roll protection (along with the air intake) noe imagine trusting your life to that at 200mph... its not very big!!
mrlee
Greeny
Post Tue Jan 09, 2007 8:46 pm
I just measured up a 2 door door and the frame is alot different to a cabby door due to the height of the sils on the cabby. I think it can be done but it's going to be a long painfull process so I think I'll wait untill I win the lottery and give it to someone else to do.
mrLEE30
Post Wed Jan 10, 2007 5:12 am
thought that would be the case, even the wing on a cab is different to a tin top, only bonnet and boot are shared (almost like an M3!!) the only way i can see this happening is to modify the window lifter in a cab door to accept a coupe window, cut away the brace, remove the quarter window and somehow get it to seal against the coupe window but allow it to wind up and down, however i also would not be surprised to find the windscreen is a slightly different angle due to the additional strength so a coupe window may not have the correct angle..... in short i would not bother!!
I like where you have gone with your cab, simliar to mine but i have not attcked the chrome trim on the doors yet!! i just fitted clear sides and front indicators but not taken pics yet.
