LSD upgrade
uberdrah
I've decided that 2007 is the year to upgrade my diff to an LSD after been driven from the UK to the Netherlands in my mates Honda S2000 for new year.
I have a 1990 325iSE, i'm not sure what ratio the diff is and at the moment its to late and the weather is to bad to look. Could anyone hazard a guess at what the ratio might be?
I'd like to keep the ratio roughly the same as it is and i'm not bothered about keep the car standard. Can one tell me if other LSD's from other models will fit?
Rich
Rich
Demlotcrew
It might be a 3.73 or 3.64 both are well sought after diffs so getting a good one which will still lock and is quiet will be almost impossible.
Wish you all the best anyway.
Andrew
Andrew
uberdrah
So does a higher ratio (3.91) make the car accelerate fast than a lower ratio (3.64) or have i got that backwards?
I've heard that LSD's from Z3's will fit E30's. Is this true? Do LSD's from other BMW's fit E30's?
3.91 makes a car accelerate faster than a 3.64, but, overdo it, 1st gear becomes useless and fifth gear becomes fourth gear. I.E. It doesn't accelerate any faster, but you end up using unnecessarily high revs at speed.
E30s (except M3 ) use a gearbox with an overdrive 5th gear and a direct (1:1) 4th gear. Later BMWs use a gearbox with a direct 5th gear, so they need a diff ratio X 0.81 that of an E30, all other things being equal.
uberdrah
Thanks for that.
Final question(s) then.
Is it true that a diff from a Z3 will fit an E30? Will a diff from any other BMW's fit an E30?
Rich
Rich
uberdrah
bump
beem
Z3 diff will fit its the only non E30 BMW diff that will fit your E30,but the output shafts need to be changed to E30 type. but will bolt right on.uberdrah wrote:Thanks for that.
Rich
The only one except for the smaller E28 5 series diffs.beem wrote: Z3 diff will fit its the only non E30 BMW diff that will fit your E30,.
Chris-W
Royalratch
Di iS' have LSD's?
What lsd would you reccommend for better acceleration at low revs? The 4.1 that comes with it?
Demlotcrew
Yus but the Z3 doesnt have a true LSD. (ZM coupe is the exception.)
gooner1
- Out humping Reindeer
Is that more or less a straight swap Chris?.Chris-W wrote:And the E36 compact.
Chris-W
suzie650
What do you mean, not a true LSD?Demlotcrew wrote:Yus but the Z3 doesnt have a true LSD. (ZM coupe is the exception.)
