Works fine from the boot & unlocks from the door...
Nope! Is that something that can be adjusted?fugazi33 wrote:Have you had the door panel off and checked the cam on the back of the barrel?
If you've done it right, it'll be good for another twenty years.Ziggy wrote:Cleaned up, adjusted, sorted.Cheers guys!
