Guys,
I've replaced the handbrake shoes on my car, and cleaned up all the widgets that sit with them behind the disc. Unfortunatly, in cleaning the bits up, I've managed to snap one of the little pressed steel retaining clips that stops the adjusting screw from rotating and slackening.
Does anyone know where I can get these? They're not shown on the ETK or RealOEM, Motormec doesn't know where you get them from, and I'm assuming that as they're not specifically shown on the ETK, my local BMW dealer won't know either.
I don't want to go buying the whole adjusting screw just on the off chance it'll come with one, as the ones I've got are fine.
Is my only option the Scrappie? Do I acctually need them? Can I get away without using them?
Ta,
Jason (AKA GOO)
Handbrake Shoe Adjusting Screw
GreatOldOne
GreatOldOne
Nobody know?
I guess it's time to go to the scap-yard then...
spence_star
Ask Nelly hes the mechanic around here
Returned after many years out.
Chris-W
cougar
Templ8e30
Discs or drums ?
If you mean drums try:
http://www.realoem.com/bmw/showparts.do ... g=34&fg=10 item number 4 ?
If so I got a set form ECP about 5 years ago for the wife's 316i, iirc they cost about 1.70p each.
If yu mean item 6 you need the whole adjuster
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
GreatOldOne
No, neither of them - it's the hand-brake shoes on a disc set-up, as per this diag:
http://www.realoem.com/bmw/showparts.do ... g=34&fg=30
It's part 7 which is the adjuster screw, but missing from the diagram is a widget that clips to the barrel of the screw and has a tongue of metal that engages with the star shaped wheel that you turn to expand and contract it. It's supposed to stop the wheel from slipping and slackening off your shoes.
I would expect it to be a part of 7
