Noise coming from the rear
Keg_gt
hi when i drive forwards or backward i get a sort of clicking noise a bit like a ratchet it starts slow and the faster you go the quicker the noise gets its almost like one click per wheel revolution but it apears to be coming form only one side the rear pasenger side. thanks for any help as would be much appriciated.
appletree
might sound abit daft but have you checked to make sure theres nothing stuck in the tyre??
i was at ATS the other day and someone had brought a wheel/tyre in and it had a M12 bolt in it but had'nt gone down, he only new it way there because of the click, click, click as it went round
bimmaman
Sounds similar to a problem I had... does the noise get louder if you accelerate harder? see this link for more... http://www.e30zone.net/modules.php?name ... highlight=
Unfortunately, I never got to the bottom of this problem, but a while back, I changed the rear shocks, and although it did make the noise once after changing them, it hasn't made any noise since...
bimmaman
Just re-read your thread, and I'm not sure mine ever made the noise going backwards...
Can be lots of causes for this, depending on the exact symptoms, but a common cause is one of the rear brake shoe securing pins pulling through the hub backplate.
Keg_gt
ok thanks guys its like a click of a ratchet and its quite loud almost a knock
liam012
rathet to me sounds like when a part of my handbrake mechanism were catching on my wheel studs because the stude holes were very inset on my dished wheels they actually went through a few mm further- i used to drive with handbrake one click up for a few days until i got it sorted,
