after reading so many stories about coolant disappearing etc I thought I better pop out and check mine.
where on earth is the marks to check the level? I can see the tank on the passangers side but there no min-max marks.
anyone?
p.s sorry for sounding stupid
checking coolant level
slinky2000
- Location: Ireland - North(Portadown) and South (Limerick)
mrLEE30
normally two lines, should be in between these when cool (normally at the bottom) and near the upper line when warm.
as a rule of thumb if the bottle is about half full when cool it will be ok. if there is too much it will spill out the overflow pipe anyway (and can knacker your paint if you use certain types of coolant)
e30bmlover
- Ac Schnitzer prophet
mine stays there with no problems.
If you have the seperate bottle, like above, the correct level is the join in the two halves, but don't be anal about it. My wife's 325 stabilizes at about 10mm below, and will quickly drop to this level again if it's topped up.
slinky2000
cheers lads, yea its the seperate bottle, its sitting about 1/2cm below it, I'll just check it regurarly just incase
