clutch cylinder/fluid problem
Taz
Post Sat Jan 06, 2007 7:50 pm
hi: guyz
need your help again....
left car parked up for 2 weeks..when i started it clutch peddle was down and floppy moved it out on the drive... i though it prob needs fluid top-up
today i put fluid in whilst engine is running and tried to pump up the peddle but the fluid is not going down or the peddle is not getting hard but feels loose and floppy
ther is no fluid on my mats do i hav to bleed it??
thanx
Post Sat Jan 06, 2007 10:30 pm
It won't work again, even temporarily, unless you bleed it, but it needs new clutch master and slave cylinders if it's going to stay working.
