E34 520i fuel pump problems
Paul_TVR
Post Sat Jan 06, 2007 5:57 pm
I know its not a E30 but thought you might be able to help still, been looking at a 520i for my neighbour as the car won't start, I found the fuel pump fuse had blown, I replaced the fuse but still the petrol pump isn't working, I removed the pump from the tank and found the two wires going to the pump had melted together and that was probably what caused the fuse to blow. I will replace the wiring but there is no voltage at the multiplug. Is the wires shorting likely to effect the fuel relay? my neighbour has said he's fed up with it and let me have it, I don't want to spend much on it by replacing everything. with the wiring sorted out the pump works so it's not that.
Post Sat Jan 06, 2007 6:00 pm
Paul_TVR
Post Sat Jan 06, 2007 6:03 pm
I have seen that but that and might bid if i can't get one locally but it won't cause the problem of the multiplug having no voltage to it?
Post Sat Jan 06, 2007 10:45 pm
I hope this M50 engine is destined to be transplanted into an E30 for this question to be allowed on this forum!!
Unless the engine is cranking or running, there won't be any voltage at the pump. Short together pins 30 and 87 of the fuel pump relay's socket and see if the pump fires up.
Post Sat Jan 06, 2007 11:56 pm
Usually the blue relay on an E34
Paul_TVR
Post Sun Jan 07, 2007 4:54 pm
Cheers for the help, nope not going to put it in a E30 but know that you guys know your bm's though thought a cheeky question wouldn't hurt lol.
I'll got try shorting the relay and see if we have power. :cool:
Paul_TVR
Post Wed Jan 10, 2007 12:15 am
All sorted, turned out the plug onto the fuel pump plus the relay connections. Don't like it though so think it'll go up for sale and get a E30 instead.
