Anti-Roll Bars-Eibach or H&R?
BIGJO
Hello people, want some advice on which anti-roll bars to take on.
Can anyone help? Any help will be much appreciated.
Regards, BJ.
Regards, BJ.
Pal318is
Have heard good things about the Eibach set up....i would presume that the H&R are on par too...
50/50 unless anyone has had experience with both...
Personally i'd go for the Eibach..
Pal
Pal
Pal
[img]http://
[img]http://
mac325i
Not had experience with the eibach setup but i am really pleased with H&R's arb's
Dan318-is
Iv got the eibach 21/16mm ( i think ) set up on mine; i had these before i put shocks on too and they change the car completely. Every e30 owner should invest in a set; make sure you change the drop links for genuine BMW ones and use a polyurethene bush too.
Iv read that the eibachs are also pretty good though!
BIGJO
I've heard mixed things about Eibach & only good about the H&R. Think they're the same quality to be honest.
Regards, BJ.
Regards, BJ.
Demlotcrew
H&R they are bigger end of.
Andrew
Andrew
Theo
Whiteline do bigger bars than H&R.....
Dan318-is
Bigger isnt necessarily better; when you pay £100 for a brand new set of eibachs im not complaining
Demlotcrew
Very true, but they start getting heavy and will require reinforcements at the attachment points, but they should not be ruled out for these reasons.Theo325 wrote:Whiteline do bigger bars than H&R.....
When you have a boat anchor for an engine i doubt weight would be a concern.
Look at this pic you can clearly see Gareth's car being very nose heavy compared to the rest of the E30s parked up.
I think ill look into getting a rear whiteline bar and use a stock 21mm cab ARB on the front but attached to the strut and not the control arm. Connecting the arb to the strut has the same effect as having a 21mm arb but using a 18mm one. (but with the added advantage of saving weight, every gram counts when trying to propel the car with a four pot
Andrew
Theo
Haha - thats a good photo there, I remember Gareth running some very inappropriate springs on his car when I saw him in March, I don't know if they were still on there - does look slammed though!
I was thinking of connecting the front ARB to the front struts like the M3 - how are you going about doing it?
Demlotcrew
I wasnt making the point of the wrong springs used on his car but the amount his car dropped on the front with the extra weight, when i fitted my S14 on H&R -35mm springs for all 4 cyl cars it hardly dropped at all.
Mate i would just buy the brackets and get them welded to a pair of struts.
Going from 18mm to 21mm is a 85% increase in stiffness
Andrew
Andrew
M5pilot
Whitelines are available upto 27mm and they are quite heavy. They only do a 16mm rear bar though but it is adjustable.
I would recommend going for uprated ARB drop links with this sort of bar, again available through Whiteline.
H&R's work very well and are cheaper than the thinner Eibach's.
I will update the shop with the Whiteline products so that you can see the difference between prices and sizes.
Sal
Sal
Theo
But his car has dropped that much due in part to the wrong springs, not just the bigger engine!
Will be interesting to have the s14 vs m30 comparison on the track I rekom - I look forward to it (i also look forward to finding a decent shell
Demlotcrew
Yeah i was aware of the rear 16mm only, but they do a cool blade type ARB for the E30
Sal are the H&R bars the largest ones for the E30 at the rear?
Andrew
Andrew
M5pilot
Hi Andrew,
I've not really looked around for any thicker roll bars for the rear. The adjustability on the H&R 18mm - would this not effectively give the force generated by a thicker anti roll bar anyway if the higher setting was used?
I spoke with Whiteline about this and the guys there seem to know their stuff, he explained how an 16mm rear can replicate a 24mm rear bar on the highest setting.
Going thicker may also have issues with clearance and fitting.
Sal
Sal
Demlotcrew
Its not that easy, different metal compositions produce different torsional stiffness so just comparing bars is actually really hard. Other factors as shape and size (arm lengths) contribute to the overall effect.
I wonder if whiteline would be able to provide some measurements along with technical data on how their bars compare to the likes of eibach or H&R.
The H&R bar on the rear is 18.5mm
But if the whiteline 16mm bar can replicate the effect of a 24mm one i would be really interested in one!
Andrew
Andrew
BIGJO
Whiteline sound the b*llocks! I wonder if they're actually better than Eibach or H&R?
Regards, BJ.
Regards, BJ.
funky-monkey
There is an upside and a down to having thicker arb's.
1) The thicker and stiffer they are the more role is reduced on the car.
2) The thicker and stiffer they are the more chance that going into and out of corners you will have less tyre contact with the road, as the opposite end with lift with the stiffness and is difficult to put the power down.
All depends on how you intend to drive the car
Just a thought.
Just a thought.
Andy335Touring
I want some H+R ARB's on mine when i've got the dosh, i think some one said they were the same size/strength as they used on either Hartge or Alpina E30's ?
It's now on -20mm(?) Spax M3 springs at the front which is about 10-15mm too low IMO
Standard 325 springs just after the swap was done, must have lowered it all of about 10mm at the mostTheo325 wrote:But his car has dropped that much due in part to the wrong springs, not just the bigger engine!
