Touring springs??
wildeian
Post Fri Jan 05, 2007 9:07 pm
I think I'm gonna go for the 60/40 look on my Touring, will any springs suffice for the front, or do they have to be 'Touring only'?
The reason I ask is I think it will be easier to pick up the fronts and rears separately, as there seems to be a few 'sport' 60 mm drops for sale.
Cheers, Ian
gareth
Post Fri Jan 05, 2007 9:32 pm
afaik the fronts will be the same in each case. there will be a very small difference in front axle weight between a tourer and saloon but not enough to make a difference.
the rears have to be touring specific though you may be able to get a way with cab ones if you find them
SPADGE
Post Fri Jan 05, 2007 9:35 pm
gareth wrote:afaik the fronts will be the same in each case. there will be a very small difference in front axle weight between a tourer and saloon but not enough to make a difference.
Axle in the front? You got a 4x4 e30 Gareth :P
Post Fri Jan 05, 2007 10:01 pm
saloon springs work fine on the rear imo. I shall see what they are like on track in the coming months
gareth
Post Fri Jan 05, 2007 10:25 pm
SPADGE wrote:Axle in the front? You got a 4x4 e30 Gareth :P
you know what i mean!!!! F/R weight splits are generally refered to as "axle weights"
that said, the thought of a 335iX is tempting :D . it has been done before too!
http://translate.google.com/translate?s ... 1025%2ehtm
Simon13 wrote: saloon springs work fine on the rear imo. I shall see what they are like on track in the coming months21
they do droop a bit though and will technically be under-rated. it would be interesting to see how yours performs though. keep us posted? :D
suzie650
Post Fri Jan 05, 2007 10:32 pm
I'll get rid of my rubbish Apex 60/40 ASAP, as the springs were most likely designed for the saloon... and therefore the car looks more like a 70/50, which means bellyscraping, on the cat. if you're slow, more dangerously to the front if you're faster...
I've also heard the cab' ones would do the job fine.
gareth
Post Fri Jan 05, 2007 10:51 pm
my 335i tourer has the wrong springs on the front and has been known to clip the exhaust on catseyes when loaded :D
suzie650
Post Fri Jan 05, 2007 11:00 pm
well, you probably have 15mm less clearence than I have :)
But you probably don't have 10 speed bumps on the driveway to college :banghead: :cry:
Did you never think of changing them?
gareth
Post Fri Jan 05, 2007 11:47 pm
yes! it wasn't too bad til i fitted the heavy old 3.5 M30 lump and lost about 20mm of clearance! i was low before that!
Post Fri Jan 05, 2007 11:50 pm
my touring is on the floor the only problem i've had is when i go to the council dump (not to scrap it!) with a full load as the twats have some very nasty speed humps there. It just grinds the centre box a touch.
Your right gareth about the ratings being out, but tbh it sits like the saloons i've with the exact same springs and shocks, it handles nicely too. I'm never going to use it for towing or carrying very heavy stuff so i am not worried.
I'll let you know how it gets on round the nurburgring when we return from the 4th trip
Post Sat Jan 06, 2007 10:34 am
SPADGE wrote: Axle in the front? You got a 4x4 e30 Gareth :P
I refer you to section 31 of the ETK "Front Axle".
SPADGE
Post Sat Jan 06, 2007 11:36 am
Bit of banter Brian between myself and Gareth but thanks :)
gareth
Post Sat Jan 06, 2007 12:10 pm
:tongue:
