Cutting out, maybe fuel - any ideas?
jkarran
Post Fri Jan 05, 2007 11:30 am
My 320 keeps dying on me sometimes it was ignition/main power failure, sometimes it seems to be fuel starved and just loses power.
I'd assumed it was the imobiliser playing up so I found the relays inside it and bypassed them crudely by cutting and twisting the relevant wires together (a bodge to finish a rally), for a few days that sorted the problem then it started recurring.
Sometimes running but missing and making little power, Turns out it had a burst fuel lin on top of the tank... scarey. Now fixed.
Then it happened again. I assumed my crappy hotwiring had corroded so soldered the joints. It ran fine... for a few minutes.
Electrical power (dash, lights etc) is on but it feels like theres no fuel. I thought I'd run it dry so filled it up... still nothing.
It takes a beating ('road' rally car) so the tank could be dented, someone has suggested that could block the inlet to the pump? I'll have to look at that.
I need to look at the fuel pump power supply obviously to make sure that's behaving.
Any other ideas... sensors (crank pos maybe)? fuel filter?
I really need to get it back on the road soon :?
Sorry for the rambling story but someone might recognise symptoms.
Cheers,
James
M5pilot
Post Fri Jan 05, 2007 11:42 am
I had this prolem and it turned out to be the fuel pump.
Get a 2nd hand one from somewhere.
Sal
JohnH
Post Fri Jan 05, 2007 11:45 am
I'd change the fuel filter straight away as its cheap and easy to do - it was the cause of really lumpy idling on my iS before it was done.
jkarran
Post Fri Jan 05, 2007 11:58 am
Cheers guys, both suspects are top of the list alongside checking fuel pump power.
Open to as many ideas as people have to give me somewhere to start from, I hate intermitant faults :cry:
jk
