Gushing petrol spill
Padzer
Post Fri Jan 05, 2007 9:11 am
Anybody else have problems at the filling station where the fuel seems to be filling too quickly and sometimes spills out and often causes the petrol pump to stop because it thinks the tank is full? The fuel doesn't seem to be travelling down to the tank quickly enough.
Post Fri Jan 05, 2007 9:21 am
You have to be careful with E30s to point the nozzle correctly in the filler pipe, otherwise the pump will cut out, but there is a large vent pipe which runs from the top of the tank (visible under the fuel pump hatch), through a metal tube under the rear seat squab, across the inside of the rear right wheel arch, and up to the filler neck.
If this tube has collapsed, then you will have problems filling.
buster
Post Fri Jan 05, 2007 12:00 pm
also,is it an m3 ? because if it is and it has the extra fuel tank,or if it has the extra tank anyway then they can be difficult to fuel up apparently.
Padzer
Post Mon Jan 08, 2007 4:39 pm
No it's a 320 touring. Thanks for that. Seem to be in the filling station quite often!
