jibbers 325 Q's
jibbers
Post Fri Apr 01, 2005 12:03 am
When i give it some revs in gear or not i get a rumble that sounds like a shot bearing , it does not do it at idle so im thinking poss bearing in viscose fan , any ideas ?
The idle is chronic but i will check the obvious later.
Are the AFM's different on 325 and 320 ?
Have just put -40 springs on the 320 and want to put them on the 325 will they go straight on or are they different ?
Any help appreciated Cheers Jibbers :D :D :D
johnono
Post Fri Apr 01, 2005 12:07 am
engine mount mabey
Zayyan
Post Fri Apr 01, 2005 12:12 am
jibbers, when did you get a 325? :D
jibbers
Post Fri Apr 01, 2005 12:16 am
I just got it tonite bout 8pm , it was a right fookin bargain , and shite what a difference in power over the 320 :D :D
