Sloppy gearchange - bush replacement questions
Two_Sheds
Post Thu Jan 04, 2007 12:12 am
At the beggining of December, I bought all the parts to do the shifter bush overhaul and Z3 lever conversion, but due to work and other things, I've only just got the time to actually follow it through. Unfortunately, I never properly checked the bag of stuff they gave me and they've left out my exhaust gasket, 2 shims and a circlip, meaning I have to do an hours round trip to pick them up.
Anyway, while trying to find a bit more information about the bush replacement, I noticed people talking about if you bought a new part 14 (selector rod joint) you also had to get a new part 11 (selector rod), as the joint had been modified. Is this true/crucial, as I didn't order a new rod (everyone just said replacing part 14 was the way forward, I basically ordered all the parts listed in the Z3 shift lever conversion page!).
I really don't fancy wasting any more time/money on this job, so can anyone tell me if its crucial that I buy a new selector rod, or will the old one fit/be modifiable?
Also, is there a really detailed guide on how to do this job anywhere? I'm a mechanical imbecile and petrified about dropping the exhaust/diff, and I've only seen a guide on how to do it for the E36 - is this applicable?
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Jan 04, 2007 12:15 am
The old type selector rod won't fit the new type bush - it won't reach through the hole, but check that you don't have the new type fitted before you order one.
Two_Sheds
Post Thu Jan 04, 2007 1:19 am
Is there any way of checking without dismantling the car?
Its an '87 325i...
Post Thu Jan 04, 2007 9:01 am
Two_Sheds wrote:Is there any way of checking without dismantling the car?
Its an '87 325i...
Get underneath!
Two_Sheds
Post Thu Jan 04, 2007 10:52 pm
Oh god, got underneath and started having a go tonight, its going to be horiffic!
Going to save it till next week when I can get it into my mates garage (more spacious/better tools) and we'll attack it then.
So am I right in thinking I have to disconnect the prop and the exhaust, then drop the gearbox down a bit to gain access to the clip and the selector rod joint?
