also after trying the windows they dont seem to run as smooth ,is there any runers to fit in doors to stop the windows moving when in the down position help
central locking
markevans
i,ve just fitted electric windows to my 1988 320i e30 first i tried to use a wiring loom from a different year then relised it was diffrent when i had no central locking and the windows only worked when doors were open, so i removed the window wiring and fited it in with original wiring everything worked then the central locking unit started making a noise and all the locks dead locked now my car is permant unlocked , i took the central locking unit apart and its been getting hot melted the plastic burnt contacts so i guess this means i need a new one any way i can undo the dead locks and have you any idea why its burnt out please help its doing my head in now
E30Mark
I had to read this three times to make any sense... random use of grammar.
Try reading this and see if it helps:- http://www.e30zone.net/modules.php?name ... ocking.htm
I don't know why you can't disable the deadlocks, never had the problem myself.
Good luck.
Good luck.
PM for details
PM for details
smithy318i
you should be able to unlock the doors individually with the key.
If you need a new central locking relay, i have one for sale. you can have it for 15 quid.
