rev counter
salami
when i start the old girl up the rev counter either does not work or today span around into the red line and stayed there.
The engine is as normal doesnt over rev any ideas thanks
wildeian
What car/engine?
Have you checked the electrical connection on the rear diff, where the speedo gets its feed from?
ian332isport
What's that got to do with the rev counterwildeian wrote:Have you checked the electrical connection on the rear diff, where the speedo gets its feed from?
It's more than likely a problem with the service interval (SI) board inside the instrument cluster.
Ian.
salami
sorry its a 87 325i
wildeian
Sorry, mis-read!!
delboye30
salami
I've checked my fuses and all seem to be ok
It worked before it went into have some welding done i wonder if when they have earthed the welder to the car it may have effected something?
nickfromgills
I've got the same problem as you, grr! Be interesting to know what's what here. I took mine in ('87, 325i) to have the NS wing replaced... unfortunately it now has no interior lights, no boot light, no glovebox light, no clock AND no rev counter... which seems weird as everything except the latter are on fuse 21... which also blows immediately I change it.
There must be a bad earth somewhere but the possilibility that some welding may have tripped things up is interesting...?
Barnz
- Guildford Geezer
My rev counter or temp gauge didn't work when I bought my 325 and solved with replacing the SI board, so I'd give that a try.... now I can see when the red line comes up in my face!!!!!!!
E34 525tds - on the way to replace 325i
E30 / 34 spares
E30 / 34 spares
Check the wiring to the boot lid around the hinge area, assuming you haven't melted any wiring on the other side/inside where you have been welding.nickfromgills wrote:I've got the same problem as you, grr! Be interesting to know what's what here. I took mine in ('87, 325i) to have the NS wing replaced... unfortunately it now has no interior lights, no boot light, no glovebox light, no clock AND no rev counter... which seems weird as everything except the latter are on fuse 21... which also blows immediately I change it.
nickfromgills
Thanks Brian... I've heard you're the local great Oracle on all things E30 and from what I've read I have no doubt!
I will check that hinge area a.s.a.p. To be honest I'm thinking that whilst I got my car back in very nice condition from the bodyshop with a new wing and a bit of work done all along the sills... the sudden appearance of the Fuse 21 issue may just be coincidence perhaps. I don't know that they actually did any welding and the front NS wing is well away from any electrical equipment protected by that fuse I think?
Hey Barnz.. I don't want to go replacing my SI board if I can help it! Besides, all works well on the dash except the tachometer and the fuel-ometer (for want of a better description)... both went at the same time as the Fuse 21 circuit... what on earth do these two have in common??
E30Mark
Also worth checking the glove-box light assembly hasn't fallen apart and shorted out.
PM for details
PM for details
nickfromgills
Yeah, I've checked that little monster in the glovebox Mark, cheers! Also all the courtesy lights.. all seems to be okay. Could be the onboard clock but I've heard that's a b***er to get out. I've just thought of something.. could be a problem with the front door light switch wires behind in front of the new wing... but getting those visible without removing the wing again is gonna be a pain, grr!
Hey sorry salami.. I didn't mean to hijack your thread - but maybe with some wise words from these helpful guys we'll both get things sorted huh? It's our tachometers we both want back I'm sure..!
Not mentioned on the fuse charts, but fuse 21 does feed the instrument cluster. It's the feed that charges the SI board batteries, IIRC. Door pin switch wires won't have anything to do with it - and they're not behind the wing, anyway.
Padzer
The rev counter and the MPG clock underneath have stopped working with mine too (an '89 320i). Not sure if it's related but a cable is hanging down that once connected somewhere in the inside of the rear wheel?
nickfromgills
If fuse 21 and the circuit it protects charges the SI board batteries then am I right in saying that all the time I'm using the car whilst this circuit is dead, the batteries are running down fast? *gulp!*... I need to get this sorted faster than I thought.
At the mo. everything on the SI board is lit.. green indicators and the 'Check' light when turning the ignition on. I've tried following the electrical diagrams in the Haynes manual but I'm no sparky really and I still have no idea why the tachometer isn't working..
does anyone know a decent mobile auto-electrician in Kent (Maidstone-ish) as I'm using the car to get to work & it's pitch black in my spare time?! It's sod's law this didn't happen in the summer when I can loll about outdoors getting my fingers burnt after work!
nickfromgills
Padzer.. I reckon you're talking about the speedometer maybe? I noticed when I replaced my diff. last summer, that the cable to this relies on pulses from the diff. I reckon it may be this that is hanging down on yours after suffering from some serious chaffing huh?!
Correct me if I'm wrong but I think the tachometer takes it's signals from the ECU..?
nickfromgills
Sorry Padzer.. I just read this properly and you say the rear wheel.. so not the speedo cable? Are you having any probs stopping??!!
Padzer wrote:The rev counter and the MPG clock underneath have stopped working with mine too (an '89 320i). Not sure if it's related but a cable is hanging down that once connected somewhere in the inside of the rear wheel?
That'll be a bodged brake wear indicator cable.Padzer wrote:Not sure if it's related but a cable is hanging down that once connected somewhere in the inside of the rear wheel?
salami
just been in for a service and it should be the si board as it has batteries on that charge up and are made for around 6 years!
the board is £103.83 from bmw or if you can solder take the board out and go to the local electronics suppliers and get 2 new batteries and solder them on £10 sir, i will try mine at the weekend.
the rev counter and fuel thingy are run through this board which is why it goes,well so my machanic told me i mean what the fcuk do i know i just ride in it
- Homo Hair
if its just the rev counter that is affected and your service lights are working fine etc, then its likely to be the rev counter module.. i had the same thing, replaced the Si board with no effect. Swapped the rev counter module and it problem solved
salami
went to work in mine last night and all started to work ok but the fuel mpg thingy was a bit wrong most of the time but counter works ok, no service lights atall now
Padzer
Hi. sorry was away for a few days. Yeah the brake pad wear warning light is on all the time, even after the last service. It's no big deal but does anybody know if this is easily fixed?
On the rev counter and MPG reader - the rev counter works some of the time but the MPG reader doesn't work at all, although both started giving trouble at the same time.
mybmw6
I had problems with my tacho, fuel gauge and OBC on my 1989 325i. When I replaced fuse 21 it blew straight away (took me 3 fuses to work that one out
I thought about what had changed and I couldn't think of anything. I did some searching and found it was two wires under were the glove box is, that were touching together. Not the glove box light wires but another two wires. These wires are + (green/red) and - (brown) and are located near the footwell a lot lower than the glove box wires (mine are cut so I don't know what they are for).
The green/red wire has constant + even with the car off (as I've found with all green/red wires in my car). When I measured the current on the fuse before it was fixed the reading was 12.65volts. After I fixed the issue with the wires touching the reading was 11.35volts. I hope this information is of some help in your trouble shooting.
Fuse 21, along with 10 and 12 are indeed used by the instrument cluster, so these three should always be checked for instrument faults.
The vandalised wires you found are earth (brown) and red/green, (not green/red), which is a permanently live 12V+ supply, through fuse 21 straight from the battery. They would have been used by some bodger to connect power some added on piece of equipment.
Any wire which has red as its main colour on an E30, and most, if not all other BMWs, will be permanently live.
