Post
Tue Jan 02, 2007 12:05 pm
My ears are burning, Mr. Davis!
Don't think you need the bank loan, lenny. I expect both your problems have the same cause, and it's not complicated.
Door pin switches have two sets of contacts on them - one for the interior lights, and one for the windows/roof, and I suspect your alarm has been connected to these latter ones.
If the windows/roof stopped working at different times for the two doors, then the problem can be solved by removing the pin switches (single self tapper - don't let the wires spring back through the hole) and cleaning them.
If they stopped working with both doors together at the same time, then the problem is with the circuit they control.
Check fuse 28 first, and listen to see if a blue relay at the back of the glovebox clicks when you open the front doors.
