any idea's as to what they might of funked up?
BELLEND MECHANICS!!
e30-unit-soldier
eko
- Old timer
Brake pad warning light,probably left it unplugged or better still snapped the wires!
Get your head behind the wheel and see
First question: Discs or drums at the rear?
rj
There is no brake light on the OBC but do you mean the Check Control Panel above the interior mirror?
Sometimes, even though the brake light bulbs look ok, the system is sensitive to old bulbs and you may still need to replace them.
toby
There's two little plugs for the warning system - assuming you have discs at rear;
one under front passenger side wheel
one under driver's side rear - if these are rear disc brakes.
With the car going up and down on a ramp (short little jerky movements
) this can shake the plugs loose.
Often the fixing for the plugs are gone so improvise with an elastic band looped over to hold the pulgs in place.
The brake light warning staying on on the check panel sounds like a bad earth at the bulb. Perhaps take the bulbs out put them back again and it will all be fine. This has cured the problem before. It is strange though.
e30-unit-soldier
disks at rear!
ill swap the light bulbs tomorrow and see what difference it makes.
First thing to make clear is that you have two independent non related faults.
If both have appeared only since your car has been worked on, then the correct course of action is to take it back and request them to put it right at their own expense.
Correct course of action, maybe, but not necessarily the most wise unless they're competent mechanics who know their way around E30s, which I suspect they're not.
Brake light warning on check panel: You realise that this is supposed to come on when you start the car, and only go out when the brakes are first used, I presume?
There's no reason whatsoever for them to have gone anywhere near any of the wiring for this warning light, but it's possible they have been at the top of the damper mounts in the boot, which would put them near the light failure sensor module mounted on the rear left inner wing, back from the wheel arch. Check the two connectors are on properly. If they've been at the boot liner, they may have disturbed the connectors to the rear lamp clusters, so remove both lamp assemblies and check everything is clean and bright inside, and try fresh bulbs if you have some handy.
Brake warning light with dots each side: This is the pad wear warning light. There is a well known fault inside the cluster that makes this light stay on all the time or flash intermittently, but your problem probably has a more human cause.
There are sensors on the front left and rear right brake pads. There is a rubber cable that is fixed to the suspension member at both corners and ends in a round two pin connector fixed to the rear of the hubs. The sensors plug into these connectors, and each consists of a small block of plastic that fixes to a brake pad, inside which is a simple loop of wire. As the pad nears the end of its life the wire first short circuits to the disc, and is then severed by it, as the plastic block wears away with the pad.
The pad warning light will come on if the wire is shorted to earth, is broken, or has any appreciable resistance (such as a poor connection at the connector). They will have had to disconnect at the front, so I would start there, but they will have been near the back wiring as well.
Incorrectly dressed wires from the caliper to the connector will rub through on the inside of the wheel rim.
