I have been trying to sort out a rough idle since buying my 325i touring a year and a half ago. Finally decided to get a new oil breather pipe and check that the tps was working properly. TPS was fine, oil breather pipe was hard but probably ok but replaced as i'd bought a replacement. The major problem was something I had not read about on any of the threads I've checked. There is an unused vacuum stub on the underside of my throttle body with a rubber bung to block it off. The rubber bung was disintigrating and alowing plenty of unmetered air in. As a temporary fix until the dealer opens on Tuesday I have put some duct tape over the stub and held in place with the remains of the old bung.
Rob
rough idle sorted
win
Hello Rob,
I was just reading about your rough idling. How can you check the tps is working and can it be cleaned out. I've had an idle problem which has inproved sinced cleaning ICV, AFM and throttle body but is still not how the 325 should run.
win
win
rmt
Use a continuity tester on the three pin socket on the switch. The middle and front pin should have continuity with the throttle closed and no continuity as soon as thottle starts to open. Do a search on this to see if the switch can be prised open to clean it. Mine was fine so I didn't need to clean or adjust it. Sometimes they fill up with oil. Don't forget all the rubber gaitors between the AFM and the throttle need to be in perfect order too. I am going to replace all mine because I can see they are past their best (but not yet leaking). The short hose between the ICV and throttle body on mine is rock hard and I suspect the seal against the throtle body is not perfect. So, I have put some tape around the stub and pushed the hose over that to make a temporary fix.
win
cheers mate i'll give that a try tomorrow i'll check all the hoses the hoses too just to make there's no leaks
this stub is the equivalent of the blocked off pipe that often gets mentioned often by M40 owners, and is frequently the cause of a rough idle on these engines when the bung falls off the end. The bung on the 325 manifold seems to have a much better survival rate than the M40 one, but if it fails, it will cause the same symptoms.rmt wrote:I have been trying to sort out a rough idle since buying my 325i touring a year and a half ago. Finally decided to get a new oil breather pipe and check that the tps was working properly. TPS was fine, oil breather pipe was hard but probably ok but replaced as i'd bought a replacement. The major problem was something I had not read about on any of the threads I've checked. There is an unused vacuum stub on the underside of my throttle body with a rubber bung to block it off. The rubber bung was disintigrating and alowing plenty of unmetered air in. As a temporary fix until the dealer opens on Tuesday I have put some duct tape over the stub and held in place with the remains of the old bung.
Rob
