short shift problems !!
y8sey
Post Fri Dec 29, 2006 8:22 pm
bought a cheap one had it fitted but i get a lot of vibration through the gearstick. Can anyone recomend a decent make??
eko
Old timer
Post Fri Dec 29, 2006 8:23 pm
Yeah,Z3 BMW from the dealers about £20 :)
OBs
Post Sat Dec 30, 2006 1:16 am
eko wrote:Yeah,Z3 BMW from the dealers about £20 :)
Eko fitted one to mine yesterday, Really good mate... Invest all of your 20 quid and enjoy!
http://www.e30zone.net/modules.php?name ... echnz3.htm
gareth
Post Sat Dec 30, 2006 10:04 am
thirded! bmw one every time!
Demlotcrew
Post Sat Dec 30, 2006 11:50 am
I bet its rubbing on the prop/vibration dampner.
Andrew
Nelly
Gumbo
Gumbo
Post Sat Dec 30, 2006 11:57 am
^^ In one Andrew, had the same problem with Sarah's one when i done the 2.5 conversion only, i couldn't select 1st + 2nd gears - removed the prop 'again' , took the vibration damper off and replaced every thing again - all works spot on now :wink:
Neil.
"I F**KING LOVE YOU GUMBO"
y8sey
Post Sat Dec 30, 2006 12:07 pm
it happens when i rest my hand on it ,the stick moves and the vibration is there. If i buy a bmw one for a z3 are they all the same? I remember reading somewhere that gearsticks for different size engines give different results
gareth
Post Sat Dec 30, 2006 12:10 pm
1.9 Z3 is what i use. there are higher ratio ones but it'll be very notchy.
the bmw stick has a rubber vibration damper within that bulge on the stem to isolate the top from the gearbox vibrations
