non start
hass
Post Thu Dec 28, 2006 10:55 pm
hi guys got a e30 (one of my customers)and he burnt out the starter.
firstly i thought ok old car starter gone ,changed it all ok
then 2 days later same problem when i checked it out he taped the igniotion key and it was jaming on crank while driving :evil:
anyway manged to send the starter bck and get another one bck from dealer fitted it and repaired the ignition key.
went to crank it over it turns over but doesnt firer up,checked for spark no spark.swapped coils over still same ive been told that its the ecu but to get one its like £150
and if its not it down to me to pay
the cars spec:316 shell with 2.5 engine transplant
old style engine with 2 pin ecu
auto!!
also i changed the gearbox pick ups to
please help guys
thanks hass
E30Mark
Post Fri Dec 29, 2006 10:58 am
Have you checked and double checked the black / green wire connection to the starter?
PM for details
Post Fri Dec 29, 2006 2:00 pm
Black/green wire on the starter motor will only stop the heater fan and windows working, not the engine!
I think I've read that the early 325 ECUs can have their problems, but generally, ECUs are very reliable, and wouldn't be very high up my list of suspects.
Difficult to suggest what might be wrong without knowing what tests you've done.
Have you checked for 12V+ at the ignition coil + terminal, both with the ignition on and when trying to start the engine? Use a 12V lamp for this test in preference to a meter, as meters give misleading results on unloaded circuits.
Have you tried bridging out the main ECU relay? (30 to any other pins with 87 on them).
Have you bridged out the fuel pump relay, and checked that fuel is being pumped through? (30 to 87).
Post Fri Dec 29, 2006 2:04 pm
With most autos you have to be in Park (P) to start them...maybe it's something to do with that circuit?
Gortour
Post Fri Dec 29, 2006 2:32 pm
320iSE wrote:With most autos you have to be in Park (P) to start them...maybe it's something to do with that circuit?
Good thinking, but if it wasn't in Park or Neutral, it wouldn't even turn over.
E30Mark
Post Fri Dec 29, 2006 5:49 pm
Brianmoooore wrote:Black/green wire on the starter motor will only stop the heater fan and windows working, not the engine!
Cheers Brian, next time I'll check my wiring diagrams before i type!
PM for details
