Anyone got any experience with these? How much lower will they make my car...
ps: A set is delivered with two off these. Each set for each spring.
bullitt wrote:Why bother.. A secondhand set of -40mm springs will cost you Ԛ£40..
False economy i think!!
Thanks! I know the front springs are a pity!!bullitt wrote:Check out these pages..
http://www.e30zone.co.uk/modules.php?na ... pic&t=4965
They will give you an idea how to fit lowering springs..
I have those spanner... changed the front-struts just a few months ago.. with some second hand ones... and needed t use the old springs.. It was a LOT of work!!low325icab wrote:if you think changing the springs is a lot of work, you wanna try putting these on your springs in the wheel arch! belive me, it easier to change the springs mate! you need two spanners and you can only turn them half a turn at at time as theres no room (this is if you do it with the shocks still fitted to the car by the way) or if you were gonna take the shock out to do it, you might as well change the springs.
