valve clearances 325
eltel
Post Wed Dec 27, 2006 3:55 pm
hi there... need your expert help again!!!!
did the valve clearances on the '88' 325i recon head... then zone told me about rule of 7 so re-did them to make sure they were right...
i set them to a tight 0.25mm so that you had to use a little bit of force to slide the feeler gauge between.
the car runs and idles well but at around 3000rpm and upwards you can still hear the tappets rattling in the car... not immensly loud but louder than my mates tourer with more miles... it is more pronounced when just tickling the throttle as opposed to accelerating.
did your test of reving car and switching off to eliminate injectors and is def tappets.
the camshaft and tappets etc were all totally brand new so dont think there is any damaged parts etc.
what im really asking is should i not have put the clearances so tight, should the gauge slide freely between or with a bit of persuasion???
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
ajm-e30
Post Wed Dec 27, 2006 4:02 pm
there should be a little bit of slide for the gauge mate if that makes any sense, iv also changed to a heavier weight oil to dampen the tappet noise aswell. hope that helps matey
kam-325i
Post Wed Dec 27, 2006 4:03 pm
when you have set the clearence, you should feel "resistance" when sliding the gauge under the eccentric wheel thingy. a feeler gauge with oil on it should be leaft with a clean track.
Post Wed Dec 27, 2006 8:05 pm
If you're not sure you've set them right, try a slightly thinner gauge afterwards (which should slide in with no resistance), and a slightly thicker one, which should have to be forced in, or not go in at all.
