Track rod ends
alan325i
Post Wed Dec 27, 2006 3:52 pm
How do you get these things off :x
I have undone the clamp, tried turning it, stuck (understatement) tried heating it, still wont budge.
Any suggestions?
Thanx
kam-325i
Post Wed Dec 27, 2006 3:57 pm
Soak the threaded ends with some very light oil.....or even diesel.....
Best stuff i have used is called "Plus Gas", its like WD40, but lighter....
http://www.lawson-his.co.uk/scripts/det ... duct=30700
ajm-e30
Post Wed Dec 27, 2006 4:04 pm
or if the above dont work get them glowing hot and then loosen them off, dont separate the the joint from the hub tho
smithy318i
Post Wed Dec 27, 2006 4:07 pm
you may have better luck if you keep the balljoint attached to the strut assy, and rotate the inner section of the rod.
alan325i
Post Wed Dec 27, 2006 4:11 pm
thanx, will give it a go and let it soak over night.
Ready for a new day of swearing and cussing. :D
alan325i
Post Wed Dec 27, 2006 5:15 pm
the struts are off car now though, as im in the process of changing all running gear.
Post Wed Dec 27, 2006 7:58 pm
There's a slot in the track rods, which allows the clamp to crush the track rod onto the rod end. Flood this slot with WD40 and use a blunt cold chisel to slightly open up the slot by hitting against the edge of the slot, but be very careful not to damage the thread on the rod end.
The WD40 will be drawn around the threads by capillary action, and the pumping action caused as the metal springs slightly apart, and after a while the threads will loosen up.
Reassemble with loads of copper grease.
