Help identifying Green/Black wires in passenger footwell
kevin316i
Post Wed Dec 27, 2006 1:33 am
Hope everyone had a nice Christmas.
I'm in the process of removing an old immobiliser from my iS which judging by the wiring was installed by a total cretin. In the passenger footwell, there are three green/black wires in the main harness coming down from the left of the glovebox taped together. I can't see any cut wires further down in the harness.
Does anyone know what these might be? Definitely not speaker wires.
I found them when tracing wires from the immobiliser back to a grey/purple wire that had been cut and connected to the immobiliser.
Out of interest, does anyone know what this wire is? The reason for asking is that if it would be useful for an alarm, I'll connect it to make it easier to splice in an additional wire at a later date for the new alarm install.
Thanks,
Kevin
Post Wed Dec 27, 2006 10:18 am
Might be having an off day, but, off hand, I can't think of any black/greens or grey/purple that has any relevance to an alarm.
Are you sure you've got main colour and tracer the right way around?
kevin316i
Post Wed Dec 27, 2006 11:20 am
Hi Brian,
I just checked again in daylight and the wire is actually green/purple which would be the fuel pump wire? Sorry for any confusion caused, was using a small handheld striplight for illumination last night.
The other three wires connected together are black with a green stripe. These weren't connected to this immobiliser but could have been part of a previous alarm install as I found scotchloks on wires behind the hazard warning switch when I replaced the stereo a while ago. However, it would be good to know what they are for.
Thanks,
Kevin
Post Wed Dec 27, 2006 1:05 pm
A green/purple that was connected to an alarm/immobiliser is very probably the fuel pump wire as you say.
Black/green is the colour of the control wire for the unloader relays, K5 and K7 (quite often gets played around with by people who don't know what they're doing), but shouldn't come down into the glovebox area.
Can you get a meter onto the joint and see if/when they are live? Try using the starter while the meter is connected.
kevin316i
Post Wed Dec 27, 2006 3:53 pm
Thanks Brian,
I'll check them out with a multimeter. The quality of the wiring proves that the person who worked on the car before didn't know what they were doing.
Regards,
Kevin
Post Wed Dec 27, 2006 6:52 pm
My iS was like this when I acquired it. I've never seen such a rat's nest of badly jointed, badly insulated wiring in my life. Two alarm systems and the audio wiring.
Fortunately, a good proportion of the damage was to the dashboard loom that plugs in at the back left of the glovebox and to the ignition switch loom, so both of these were replaced.
There are still a few joints on the car that shouldn't be there, but at least they're now soldered and heat shrink insulated.
