help! juddering--no fuel pressure now dead @ side of road
liam012
Post Tue Dec 26, 2006 6:12 pm
well started off like a nice bright crispyboxing day on the way to a car meet
car starts running very rough - lean then normal then lean up through the revs,
idle went p1ss poor too
city driving under 1500rpm impossible to do as shaking almost stalling
get on to open road and not as bad but lean and rich spots all over the place surge surge etc.
eventually died at the side of the road while trying to idle
even resrted to the afm for adjustment at the last minute which strange improved the idle to perfect for a nminute until she died at the side of the road,
funny thing is after looking at everything (boot full of tools bar multimetre though used a fog light and wire mcgiuver style!) popped the fuel filter and the car is getting no petrol at ignition 1 or cranking
any ideas what this could be
also wondering how the fuel pump can be removed as it sounds like a dying fuel pump
a relay wont make it progressively worse will it - it just works or doesnt - there is no in between
i am tired and have just been towed home after 4 hours at the side of a dual carriage way
if anyone has any ideas what was happening to me motor would love to know
thankssw
Post Tue Dec 26, 2006 6:31 pm
Pull the fuel pump relay and short together pins 30 and 87 of its socket. If no fuel comes out of the fuel supply line to the fuel rail, you are probably either out of petrol or the pump has failed.
Very easy to get at - pull up the rear seat base and remove the black oval cover on the right hand side. Good smack on its top usually brings it back to temporary life.
liam012
Post Tue Dec 26, 2006 7:38 pm
cheers brian
after swapping the horn relay for the fuel pump relay and still nothing so can assume a dead pump
due to darkeness being cold hungry and down right miserable feeling sorry for myself have decided to call it a day for today.
one thing on my mind an intermitttent ptoblem that has come and gone twice since the engine rebuild (fuel pump-tank unused for 3 months may eplain failure) is what seems like a split second system shutdown as in the car seems to missfire so badly it stalls for a second causing temp guage and mpg guage to rest at zero for a millisecond - the miss is so quick that it doesnt stall completely and the needles pop back in to correct position - i had suspected it was a loose alternator wire causing a short/bad earth but in hindsight it could of been the injector cleaner i put in that day that actually fixed the problem until now as today it was doing the needle jumping thing again when it began to run rough. mmmm?
Post Tue Dec 26, 2006 7:50 pm
Swapping the relays over tests nothing other than the relay. You have to link across 30 and 87 like I said.
In light of the extra symptoms you've now described, check the connections of the two smaller wires on the battery + terminal first.
liam012
Post Wed Dec 27, 2006 6:50 pm
mmm bridged connections
nothing
walloped pump with screwdriver
pump ran for few seconds then cut out
did three times now it is staying on good
hext thing i start car
horay it runs albeit a tad rough
until it is almost warm
cuts out and dead again wont start?
now i knoow it is getting fuel and spark
and now and then it tries to start
is this pointing to a faulty blue temp sensor?
its only as few weeks old
i think i may have forgotten the turns i made in desperation on the AFM :(
i feel syipid now i tell you
is there any way to get some sort of basic setting on the mixture screw to get it running
i'll get the co done straight away but i am wondering if anyone knows any tricks like "close it all the way then open it 3 turns" sort of job that at least will not have an adverse affect on the car starting/idliing
thanks again
Post Wed Dec 27, 2006 7:19 pm
You sure the pump hasn't quit again? An E30 should start and idle quite happily with the entire AFM disconnected.
liam012
Post Wed Dec 27, 2006 7:29 pm
really? thats bizzarre ii thouh the afm controlled the idle mixture?
ll try the pump again so but i can hear it going when the car is not running so dont think so
unless the fuel system needs flushing - can hear it circulating goodo though.
it ran fine till it warmed up. :(
Post Wed Dec 27, 2006 7:36 pm
AFM isn't used at idle, (if the TPS is working), but a faulty one can give incorrect signals that confuses the ECU.
The signal for the blue temp sensor goes through a plug and socket fixed to the metalwork under the inlet manifold, that can often get corroded, so check this out.
Fuel pump may be running, but it may not be developing sufficient pressure. If it's stopped once, it's scrap, so replace it ASAP.
liam012
Post Thu Dec 28, 2006 4:03 pm
ok tps was not giving WOT - have removed cleaned and replacxed and getting the right continuity in the right places.
have replaced dme and hard wired fuel pump for now
again started the car and it idled absolutely perfect until up to 1/3 of the temp and car just cuts out and refuses to start again.
am having a coffee now and if it starts again perfectr in an hour i'll konw its temp related surely?
the pump is probably scrap - but when the car cuts out now i can hear it running still - could the increase in temp drop the fuel pressure?
or maybe the wiring for blue temp sensor is faulty - how best to test that?
liam012
Post Thu Dec 28, 2006 4:39 pm
ok - let it cool down and no go....
pump is whirring but now i am getting no spark - what on earth is going on
also the pump doesnt want to run with a relay - only hot wired....
getting morer and more confused
Post Thu Dec 28, 2006 5:26 pm
Temp related fuel pump and spark failure is usually a crank position sensor on its way out.
Connector for this is under the diagnostic socket, and there should be about 540 ohms across the two pins nearest the lead. Yours is intermittent at the moment, so a reading of 540 ohms won't confirm a good one, although an open circuit or intermittent reading would mean a dud one.
liam012
Post Thu Dec 28, 2006 8:20 pm
yep i am begininning to think so
funny, today when i started it after revovering WOT and cleaning the tps, and replacing the DME relay it really never had idled so sweet from cold, funny especially as the battery was unplugged last night and i thiught it would be all over the shop but it just wodered for 3 seconds when i started it and idled perfect better than ever -
it then when it reached a certtain temp just cut out without warning or rough running like someone had switched it off - if a faulty coolant sensor i imagine it would have ran progressively worse/richer until it cut out - couple that with the now lack of spark and pump only running when hot wired i think a cps is on the money - i will know when i replace it after lunch tommorow -
to add (this is me thinking aloud more than anything now so excuse me!) - could this explain the problem i was having with kangarooing trying to keepp the car steady at 30mph constant in 4th gear off throttle? i ask as the bently says if you are having trouble maintaining constant speeds then check cps,
if swapping this sensor solves that issue too i will be a very very happy man!
brian, thanks for all your help and advice mate - true hero. :thumb:
Post Thu Dec 28, 2006 8:27 pm
liam012 wrote:- could this explain the problem i was having with kangarooing trying to keepp the car steady at 30mph constant in 4th gear off throttle? i ask as the bently says if you are having trouble maintaining constant speeds then check cps,
My wife's touring has this problem when running on petrol only - absolutely fine on LPG, so I doubt if it's anything to do with the CPS on hers, but, as I said in another thread, I haven't had the time/motivation to track the problem down yet.
