For a while i have noticed a slight drop in performance and when the engine idles the revs fluctuate a little then when i accelerate the engines seems to choke slightly then the revs increase. in addition to this the fuel pump can be heard easily compared to other e30's i have had in the past, and when the accelerator is pressed the niose from the pump increases.
anyone have any ideas?
is my fuel pump going to die????
Is this an early car with the in tank lift pump and a seperate pressure pump in front of the rear left wheel arch?
louis2035
its a 1991 325 i sport, isnt it just the fuel pump under the rear seats?
No '91 car should have the twin pump set up, so that's that theory gone.
Think any perceived change in the noise from the fuel pump is a red herring. They tend to either work or stop in my experience.
Check out the air hose between the air meter and the throttle body for splits and cracks, and check the operation of the throttle position switch.
louis2035
i did recently fit a new k&n induction, so i might not have tightened and replaced the hose correctly. i will check it out
