Help with cruise control fitment please
DORAS
Post Sun Dec 24, 2006 1:44 pm
I aquired a cruise control kit to install in my manual 325 sport, it was removed from a 1990 325 se auto. i have just had a look through previous posts and found i need the clutch switch and bracket which isn't a problem but i cannot find any spare connectors under the dash/behind the glove box, i have pulled the insulation back and cant find any. do i need to splice them in or should the connectors be there?
any help would be appreciated as i am outside freezing my n*uts of getting wound up!
Post Sun Dec 24, 2006 1:49 pm
connections are to the accessories socket at the back of the glovebox.
DORAS
Post Sun Dec 24, 2006 2:00 pm
is that the big white connector block mate?
DORAS
Post Sun Dec 24, 2006 2:45 pm
i have got the loom in front of me and so far i have worked out, not 100% sure, i have a blue that i think is only used on a auto so thats spare, a brown that needs earthing to the body, a 2 pin connector with one pink and white wire and the other green and brown with i assume connect into the big white connector block behind the glovebox. the large blue connector obviously to the ecu. the single blue and yellow to the green connector block on the back of the instrument cluster (choice of 3 connectors?) the 2 pin white connector to the clutch switch and thats it.
am i barking up the right tree??
klu99apm
Post Sun Dec 24, 2006 7:38 pm
I think you've got that all right (I fitted cruise to mine 6 months ago)
I don't think it matters which of the 3 connections you use on the back of the green connector.
Good luck fitting it - hopefully you'll find some roads empty enough to use it on :)
nickso
Post Sun Dec 24, 2006 9:00 pm
DORAS wrote:i have got the loom in front of me and so far i have worked out, not 100% sure, i have a blue that i think is only used on a auto so thats spare, a brown that needs earthing to the body, a 2 pin connector with one pink and white wire and the other green and brown with i assume connect into the big white connector block behind the glovebox. the large blue connector obviously to the ecu. the single blue and yellow to the green connector block on the back of the instrument cluster (choice of 3 connectors?) the 2 pin white connector to the clutch switch and thats it.
i have a cruise control fitting guide/diagram on .pdf if you want a copy pm me your email address :D
'88 e30 328i M52 track bint.
