I have got the lovly job of doing the water pump on chris motor over the christmas period.
Im trying to source a new pump and gasket over christmas break and im gonna fit it.
Is it a har done to do or is it striaght forward??
thanks
Neil
Water Pump for 318iS
cliffybabe
- Powered by Nelly
E30Mark
Assuming the old one isn't seized into the block then it's an easy job, remove the securing bolts and then strew two of them back into the appropriate threaded holes on the pump body and screw them back in, this should help jack the pump off the block. Otherwise you might end end smashing it to bits! warm the engine up a little too, help keep your little fingers warm!
PM for details
PM for details
