Heater temp with aircon fitted.
ian332isport
Guys,
This is a question for the few peeps with aircon fitted.
What sort of temperature do you get out of your heater ?
Before I fitted aircon, my heater got hot enough to nearly burn you if you put your hand close to the vents. Since fitting aircon, the temperature is somewhat reduced, almost to the point of the car being uncomfortably cool when driving.
Not sure if it's relevant (don't see why it should be), but my original heater was the plastic piped version, and the aircon heater is the aluminium piped version (all aircon heaters have alloy pipes - I think).
I guess it could be a partially blocked matrix or valve, but wanted to make sure it wasn't something fundamentally different on aircon equipped cars before I go throwing new parts at it.
Ian.
Ian.
oze30
minbe burns me.. spadge keeps complaining when he gets in. I think it could be a bleeding prob??
ian332isport
I very much doubt that. I fitted the aircon several years ago. Air locks in the system usually result in no heat, rather than low heat. It does give out heat, just not as much as it used to, or as much as I would like.oze30 wrote:could be a bleeding prob??
Ian.
oze30
maybe water pump? poor circulation.. no heat.. only latent heat from the engine heating up the heater pipes.. thermostat not opening?
i dunno..
Running out of things to suggest as its a closed loop system that runs from everything else eg: rad, engine, thermostat, matrix.
Brian???
i dunno..
Brian???
mrLEE30
both mine had/have (sport/cab) the factory air con and the heater is as hot as any E30 i have owned even the ones in UK without A/C. is your A/C compressor on all the time or does it come off with the A/C button?? I have not checked which heater matrix i have but if you want i can have a look.
mrlee
mrlee
ian332isport
My A/C compressor only runs when the A/C is switched on (operates the same as a standard factory fit setup). I have also integrated it with the S50 ECU so that the compressor drops out on full throttlemrLEE30 wrote:is your A/C compressor on all the time or does it come off with the A/C button??
It sounds like I have a flow restriction in the heater somewhere (valve or matrix), that needs looking at. I just wanted to make sure it wasn't a 'feature' of E30 A/C.
Ian.
Demlotcrew
Ian what about having a look at the orientation of the pipes into the heater matrix?
Andrew
Andrew
ian332isport
Hi Andrew,Demlotcrew wrote:Ian what about having a look at the orientation of the pipes into the heater matrix?
Andrew
I've already checked that. If you get them reversed, you get an audible thumping noise as the valve gets lifted off it's seat because the flow is in the wrong direction. Been there - done that
I do get heat, just not as much as I should.
Ian.
wiledw
The 318is has A/C from factory and blows very hot.
Demlotcrew
Well the good news is that you can take the heater matrix out with relative ease, as you only need to take a few covers off the glovebox.
Im not really sure what else it could be.
Andrew
Andrew
ian332isport
Hi Andrew,Demlotcrew wrote:Well the good news is that you can take the heater matrix out with relative ease, as you only need to take a few covers off the glovebox.
Andrew
Yeah, I know it's not a huge job (had the matrix out before). I think it can only be the valve or the matrix. These are the only things that changed when I fitted the A/C. I'll probably replace both at the same time as it's a fiddly old job. I'd hate to do the matrix only to find I need to repeat most of the labour to change the valve (or visa-versa).
I'll get my Xenon's in first though
Ian.
Demlotcrew
He he
I have started on them!
Andrew
Andrew
DJ_B4L
try bleeding the system mate i had a similar problem with my normal heating without A/c i left the cap off the resovoir from cold let the engine run with it, engine will heat up and leave the air blowing mine was cold after a while it started heating up and the water collant went steady any air will come out.
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
oze30
So the matrix is the same as a non A/C one? Might need mine changing when I get back to the UKDemlotcrew wrote:Well the good news is that you can take the heater matrix out with relative ease, as you only need to take a few covers off the glovebox.
Andrew
ian332isport
Yes.oze30 wrote:So the matrix is the same as a non A/C one?
If it has the same matrix, then surely it should have a similar output, apart from a little extra air resistance by the cooling bits.
Have you checked that the blending flap cable is set right, and not still bleeding in cold air at full hot?
ian332isport
Brian,Brianmoooore wrote:Have you checked that the blending flap cable is set right, and not still bleeding in cold air at full hot?
I'm pretty sure I set all the flaps up when I installed it (fitted a new set of sliders as the originals were damaged), but it's something I hadn't considered. I'll certainly check that before buying any new parts.
Thanks,
Ian.
