Hi all
I am trying to remove the wiper motor from my 1985 LHD 325ie and am having an absolute nightmare.
I looked at the guide by PeterE30Tourer http://www.e30zone.net/modules.php?name ... wipers.htm
but the photos that he has in that guide look nothing like what I can see through the air vent hole.
I've been trying for two days now to get this motor out and all I've succeeded in doing is smashing my hands repeatedly on the engine and ripping my skin off trying to access the bolts on the motor (which are placed in the stupidest places imaginable).
The plastic shroud surrounding the motor, I have had to cut off piece by piece with a Stanley knife because it just made access to the whole compartment impossible.
In PeterE30Tourer's guide, when you look at the picture through the air vent hole, you can clearly see the bolts that are holding the whole thing together, whereas through my vent, you can see the mechanism, but there is not a single bolt on it...Just some kind of little flat-headed pins that are holding it all together.
The motor itself is bolted to some kind of black metal plate (the bracket ?) which in turn was bolted to the car itself....I managed to remove this bolt and the motor will move back and forth, bu the bracket that it is stuck to appears to be welded to a black metal tube (which I assume is the linkage ?) and no matter what I try, I cannot get the motor to come away from the bracket.....I undid three tiny 10mm bolts on the bottom of the bracket which appeared to be holding the motor on, but to no avail...Because the compartment is so tiny, and access to try and see what the problem is, even after taking the soundproof panel off is nigh on impossible, am I better off just cutting the linkage apart with an angle grinder, pulling the whole lot out piece by piece, and just getting a proper one from a scrapyard along with a new motor ?
I don't know what kind of imbecile designed the setup that I have at the minute, but it certainly doesn't match the one in the guide.
In summary, the main problem that I am having is actually detaching the motor from the linkage and from the bracket that was secured to the car itself by one large bolt (which I think is the bolt that PeterE30Touring must have meant when he says in the guide that the soundproof panel has to be taken off to access it.)
According to the guide, there are three bolts which hold this bracket in place, but on my car there was only one, which I have undone, and the bracket itself now moves freely, but the motor is still attached to the bracket and is still attached to the linkage with no obvious way to remove it.
Any help from anyone that has had a similar problem will be most appreciated !
Many thanks
Tom
Front wiper motor removal - Please help !
Templ8e30
I've had several motors out of different e30's and they all looked exactly like the ones in the photo
The motor is attached to the bracket with 3 10mm headed bolts and the bracket is attached to the car by 3 10mm headed nuts. The bracket sandwiches the plastic cover to the car body.
The linkage is attached to the crank arm by a plastic socket which needs to be prised upwards with a screwdriver so it'll pop off.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
johnl320
Take a photo fella , a picture paints.... and all that shite
john
john
oze30
Theres an 8mm nut that hold the wiper arm to the motor.
Three 10mm I think bolts hold the motor to the bracket immediately under the little wiper stub
3 I think 13mm washer nuts hold the bracket to the body
BUT.. You need to pull the weather seal up from th etop of the bonnet opening, and undo the 9mm plasti-nuts there (I think 2-about an inch-1.5 inches from the bottom)
Once youve done this, the wiper motor... after youve undone the above bolts, should just twist and turn to get out.
Thats how it works for a RHD, not sure bout LHD
Chris-W
oze30
Sorry.. as per chris ( Im in oz, cars in UK!!!)Chris-W wrote:All the nuts holding the motor to the bracket and the bracket to the car are 10mm, and you'll need a 7mm socket to pull the bulkhead cover away far enough to get the motor out.
