318is M42 inlet manifold removal
mark_i
Post Wed Dec 20, 2006 10:15 am
Can the M42 inlet manifold gaskets be reused?
I have to fix a petrol leak pouring out of the fuel injector rail connector.
Inlet manifold removal looks like the only way to get access to the fuel hoses, so I need to know if any of the gaskets get damaged.
bobafett
Post Wed Dec 20, 2006 10:55 am
Depends on if its a metal gasket or not, unfortunately you can only tell by splitting the top half off. You should only need to remove the upper section of the manifold as the fuel lines are mounted to rail between upper and lower mainfold sections.
If the gasket is metal then your fine but if its a paper one just take it steady and it shouldn't tear. :o: Watch out for the locating dowels for the studs that run up from the lower section as they can come loose and fall in to the lower bit and you might have to take it off to get them out. :x
Good luck my friend... :)
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
mark_i
Post Wed Dec 20, 2006 11:18 am
thanks bobafett, good reminder about the dowels dropping out.
btw you're not the bloke from those Paul Calf Video diaries are you? :)
bobafett
Post Wed Dec 20, 2006 11:52 am
Not that i know of :D
Cool bounty hunter from Star Wars mate......
mark_i
Post Fri Dec 29, 2006 8:47 pm
Never as simple as you first think, some advice please.
The throttle body heat exchangers were totally different to the picture on realoem.com and I had to disconnect the coolant hoses.
Isn't there a mod to bypass this feature with a piece of tubing? Never gets cold enough here to make a difference.
Once I got the upper manifold off, I then tried to see exactly from where the fuel was leaking.
The two small in/out hoses looked good with no splits.
With the aid of a small mirror and torch, I could see under the fuel rail and it appeared as though there had been a leak from where the inlet tube is welded/attached to the rail.
Anyone seen this before?
How to remove the fuel rail without damaging the injectors?
The engine is an 1990 M42/318is
Dan318-is
Post Sat Dec 30, 2006 12:23 am
The fuel pipe that will be leaking is a 15 year old 2.5 inch small piece of rubber tube; a high pressure fuel line that provides fuel from the top of the fuel filter to the rail; its a common fault for a leak as is the return pipe right next to it; replace both it takes about ten minutes.
The top half of the inlet manifold as far as i am aware (and as far as i have ever seen) is the paper type. Iv been told it can be reused if it has not been on there for long but anything over a few years i would change, they are about a fiver from bmw.
The fuel rail can be removed by gently using the claw end of most household hammers to simply pop the injectors out of there place; the o rings will probably need replacing and the end of the injectors are best cleaned with carb cleaner; it might even stop some tapping noises if your lucky.
The heater plate can be chucked away to lower incoming air temperatures; its simply a case of replumbing whats there so the coolant recirculates; youl need to shorted one of the pipes; its all self explanitary when removed but make sure its not leaking before you put everything back
HTH
mark_i
Post Sat Dec 30, 2006 10:56 am
Thanks for the info there, I did start removal of the pipes and fuel rail before reading this so have ended up in not a good place.
After removing the injector clips, the fuel rail was still hard to release. Eventually it popped off and three of the o-rings went flying through the air. One ended up on the ground, one on the engine next to the alternator, the third,
no sign anywhere. I'm now worried it may have fallen inside cylinder #4 as the inlet valves were open.
Interesting that the 15 year old injectors were very clean, not so the lower manifold block that had some pretty thick internal oily deposits from the rocker breather fumes.
As for the wierd throttle body heater plate, any ideas for the best material, dimensions and pipe shape to short out the coolant flow?
Cheers, Mark
Dan318-is
Post Sat Dec 30, 2006 4:52 pm
Use the one thats already on tehre and just cut it down to size!
mark_i
Post Sat Jan 06, 2007 10:46 am
Managed to find the missing injector o-ring thanks to spraying around with compressed air.
I seem to remember reading that the o-rings need lubricating with SAE 80 oil, is that for real?
Replaced the two short fuel lines, put everything back and then discovered the battery was flat...
Three more questions...
1/ to prime the throttle body heaters with coolant, I squeezed the heater pipes and noticed a light metallic clunking
sound from the water pump area. Same noise when squeezing and releasing the upper radiator hose.
Defective thermostat?
2/ the two temp sensors: blue at the front, next to cylinder #1, brown behind, next to cylinder #2 inlet, correct?
3/ which of the Motronic components can be damaged if unplugged with the battery still connected?
Obviously the AFM, TPS, ICV and injectors have been disconnected, just wanna be sure I haven't caused more problems than fixing.
mark_i
Post Thu Jan 11, 2007 10:24 am
I know you are all waiting to hear how this repair finished up...
Jump started the engine and fired up after 5 seconds which for the record proves what a decent bit of gear the e30 is.
Obviously the idle was a little rough initially but settled down within 2 minutes. No water leaks nor vacuum leaks.
In fact, removing the rocker breather tube made the idle dance up and down but returned to 800 rpm with the tube in place.
What is worth noting is that
1/a decent fuel pump has no problem pressurising a totally empty injector rail within seconds and
2/the quality of the engineering means that you can be confident to take apart a 16-year old inlet manifold assembly and put it back together knowing that everything works as it should.
I'm still interested in answers to the thermostat and Motronic components questions from the previous reply.
The sensors colours threw me 'cause the blue had turned grey and the brown turned yellow.
