might be getting a free diff off a 320i will it fit and make much of a differance to the 318i touring it would be going on to?
cheers ian
fitting a freeby
stitch-626
wanted passenger side rear door for touring.pref dark blue
wanted, toy Bmw's any series, not for me for my 3year old daughter.
I have a rondevous with death, i drive an E30 in scotland
Don't have the actual ratios to hand, but wouldn't think there's going to be much difference between them.
oze30
320 is a 4.27 i think? 318 is 3.9-4.1???
Richy325iTouring
both 320's ive had have been 4.1
johnl320
Removed the shagged diif off my 320 ( post facelift) about a year ago. It was 4.10. went 3.64 which was a bit tall. Now running a 3.91 which is fine. I don't you'll have any dramas
HTH
john
HTH
john
Chris-W
Generally speaking, tourings and automatics will have one ratio higher than saloons, and auto tourings two ratios higher. Also some E30 models have had a change by one ratio along their production run at some time.
FlashBastd
I think mine is a 4.27, and I was told that 320i and 316i autos should most likely have the same diff as mine.
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
stitch-626
thanx for the info guys. will it have much of an effect on the old MPGige?
Strangely enough, none whatsoever if it's the same ratio!stitch-626 wrote:. will it have much of an effect on the old MPGige?
If the new one is higher numerically you will gain acceleration at the expense of MPG, and vice verse, assuming the two diffs aren't too dissimilar.
