How easy is it going to be to put a 325 engine into my 1992 E30??
Apart from the 2.5 engine what else am I going to need??
325 engine into my 316??
320stu
jon_pure_british
brakes. suspension and other things, cant really think
Clacton-On-Sea
Essex
Essex
Richy325iTouring
gear box diff
have most bits here
have most bits here
fuzzy
easy enough if your handy with the spanners.im sure if you do a search there will be plenty of info on here
320stu
What sort of money am I looking at to buy everything I need
Richy325iTouring
pm sent
jon_pure_british
oh yea, get an lsd from the donor car if you end up buying some clapped out 325 with decent engine
Clacton-On-Sea
Essex
Essex
There's a lot of differences suspension/running gear wise between a 316 and a 325 saloon. (Hardly any if they were both tourings).
Best plan, if there are good reasons to keep your present car and not just sell it and buy a 325, is to buy a rust expired or crash damaged 325 and swap over the complete front suspension, subframe, engine and box as one complete unit (lift the body off), swap the complete rear beam and suspension as well, and finally swap the coding plug from the instrument cluster.
Replace any suspect rubber bits along the way, check out the rear brake lines and fuel tank while they're accessible, and you'll end up with a first class 325, plus a host of spares or ebay fodder.
bmwe30mtech
Rear brakes also will probably need changing from drum to disk. Also rear anti roll bar.
bigmattpowell
If I were to do 325i into my 318i touring, is it just front springs then engine,box,exhaust,prop,electrics,hoses,ecu. I should have rear ARB n'est ce pas? Got rear discs.There's a lot of differences suspension/running gear wise between a 316 and a 325 saloon. (Hardly any if they were both tourings).
320stu
Think Im going to sell it and get a 325
SPADGE
Yes you have everything else already!bigmattpowell wrote:If I were to do 325i into my 318i touring, is it just front springs then engine,box,exhaust,prop,electrics,hoses,ecu. I should have rear ARB n'est ce pas? Got rear discs.There's a lot of differences suspension/running gear wise between a 316 and a 325 saloon. (Hardly any if they were both tourings).
