Cooling system
RugbySteve
Post Tue Dec 19, 2006 8:39 am
My temp dial is playing silly games with me it seems! I have a M10 318 which has a new Rad, new coolant and a new Thermostat. Yet the temp gauge when she gets upto working levels moves about. It either sits on half way or slightly over and if you put the heat on hot it moves again and then once more if you turn the heat down!!!
Any idea's on this!!?? I have a 400 mile round drive to do in her on Boxing day / day after and dont want to either overheat or kill the engine!!
Is it a case that my dial is faulty or that the sensor needs changing maybe?!!?!
Look forward to your thoughts as I need to make any replacements this weekend before I go if needed!!!
Cheers!!!
E30Mark
Post Tue Dec 19, 2006 8:42 am
If it's not going over 3/4 then don't worry about it!
There is a securing nut on the back of the temp gauge, this may need tightening as they do tend to work loose... you need to remove the cluster to get to the nut :D
PM for details
RugbySteve
Post Tue Dec 19, 2006 9:02 am
So basically if she doesnt hit 3/4 its fine and dandy to drive her normally!?!?
Oh and if I wanted to, how would I remove the cluster?!?! That sounds like a 'interesting' job!! 8O
Brian28
Post Tue Dec 19, 2006 9:26 am
Is there any air in the system? Heater may be moving water around so the sensor picks up water rather than air temp. Or vice versa
RugbySteve
Post Tue Dec 19, 2006 9:36 am
As far as im aware there is no air in the system, I did had a air block when I changed the thermostat and refilled with coolant, but sorted this and she ran fine after she was bled!!!!
