fuse blowing....
dilo_attax
my fuse keeps blowin the 10amp one for the heaters and headlights and the clocks..... what could be the problem and how can i fix it? cheers!
smithy318i
which fuse number ?
dilo_attax
im not sure, but it the 1 for the full headlights, the dails are not working and the heaters aint working, i have put a fuse in and everythnk was working 4 a while then everythnk went off i cheched the fuse an it was blown....
smithy318i
Hmmmmm that doesnt help.
Headlights use different fuses and are not connected to the heater.
does the radio work?
http://www.e30zone.net/modules.php?name ... 0fuses.htm
dilo_attax
yeah ive just checked, looking at the fuse box from the passenger side, its the sixth fuse from the right on the top set of fuses..... The cars a 325i... erm as i mentioned before the full headlights go off when the fuse blow (dims stay on) the heaters stop working and the dials stop working....
smithy318i
fuse 10 (should be 7.5A)
It's probably your reverse light switch wire rubbing against the bodywork. unclip the gear lever gaitor and unplug the white plug with the green wires. (i think they are green)
smithy318i
