Removing the front panel(facelift model)
shane325i
Post Mon Dec 18, 2006 2:14 pm
Before i start taking the car apart can anybody tell me how to remove the front panel of the car?Its the bit that sits between the front wings and holds the foglights etc.......Is it just bolted in place or will it be welded?
Many thanks,shane :wink:
smithy318i
Post Mon Dec 18, 2006 2:21 pm
It is bolted in place.
remove the black plastic bumper guides at the front of the wing.
remove the headlight grilles too
there are bolts behind the bottom plastic bit too
and then all of the small bolts which hold the front panel onto the car
WillG
Post Mon Dec 18, 2006 2:22 pm
its bolted, held by plastic bumper brackets and 1 screw at each side, 2 screws top and bottom into wing, 2 screws in middle at top which screw into slam panel and 2 screws in middle at bottom screwing into slam panel, you will need to take your plastic grills off first ofcourse
shane325i
Post Mon Dec 18, 2006 2:23 pm
:thumb: Cheers mate,i'll get stuck in then!
