Hesitant revving on a 320i (new owner...)
pictonroad
Post Mon Dec 18, 2006 10:52 am
First post. :D
Morning all, dreadful weather down here on the south coast....
Anyway, yesterday I went to look at a lovely 320i to satisfy my long held desire to own an example of this 80s classic.
Great car and I've pretty much signed the deal but it needs a little looking at.
When you floor the throttle there's a slight reluctance to pick up revs, just a bit of a delay.
Now, I'll do all the filter, plugs and leads when I get it, but are there any sensors that can cause this hesitancy that I should look to replace?
I've only known VW so this engine is a new one on me.
Any advice greatfully received.
James
jmc330i
Post Mon Dec 18, 2006 12:00 pm
Welcome mate :thumb:
Give it a good service, plugs etc and clean the TB, ICV, check all the intake pipes for splits/leaks - might not be the cause, but it wont be helping.
Once all that is done, you will know that its in good order and if the problem is still there you can start looking else where.
James
'91 325i Sport
'93 318i touring 16v
6inline
Post Mon Dec 18, 2006 12:15 pm
What year is it? Is it L-jetronic or Motronic?
pictonroad
Post Mon Dec 18, 2006 12:17 pm
G PLATE 320I SE, registereed in 89.
andy_m
Post Wed Dec 20, 2006 9:53 pm
Hi pictonroad
My H-plate 320i cabriolet is the same but only when it's cold.
My local indy (a BMW Master Technician now working for himself) recently rebuilt my gearshift and I mentioned the problem to him, apparently this is a common fault on the 320i M20 engine when it gets a few miles under its belt.
It can be rectified with a kit costing about £150 (I think that's how much he said)
Andy
ajm-e30
Post Thu Dec 21, 2006 4:25 pm
what kit is this then??
bmwscorpion
Post Thu Dec 21, 2006 4:59 pm
I had the same problem on my late 320i Traced it back to a split breather hose from the rocker cover under the manifold to the TB. it is hard to see the pipe let alone see if its split but its worth looking at..
Sorted it for me,
Morat
Post Thu Dec 21, 2006 7:37 pm
I've had it on mine (325) and I've seen a lot of posts on it. Most people find an air leak on the inlet side, usually one of the rubber hoses. I bought a new rubber hose (the fat corrugated 90degree one) for about £15 from the dealer.
I've never heard of a kit for it, although there are a fair few things that you may need to check. Ask the guy whats in the kit and post it up here?
E30Mark
Post Mon Jan 22, 2007 9:09 am
Welcome!
Where about on the South coast are you then?
A few guys have been discussing the juddering here:-
http://www.e30zone.net/modules.php?name ... ic&t=49677
PM for details
