sunroof
BIGBAZ
hi i recently brought a 316, nice car but the sunroof is not in the tracks properly and makes the car look bad how can i replace it as it is not in the haynes manual?
If you mean it's not sitting level in the hatch, then put the roof half way back, pull down the front edge of the fabric bottom piece (5 or 6 spring clips), and slide it back out of the way.
Now put the roof into the tilt position, and from inside the car looking out to the sides of the panel you will see six torx bolts that hold the panel in place. These bolts sit in oversize square holes, so slacken them off and position the panel as you require. Trial and error is required, as you can't adjust it when the roof is closed.
