Changing head gasket
seanboy
Post Sat Dec 16, 2006 10:28 pm
Tomorrow going to atempt to change the head gasket on my 2.5 m20. got timing belt, gaskets and new bolts. Read through haynes manual got a brief idea. just wondering if anyone had any other tips cheers.[/i]
kam-325i
Post Sat Dec 16, 2006 10:32 pm
I just about to start mine aswell.....
Make sure you've got all the nuts and bolts, Line up the timimg marks before putting head on, little bit easier. thats all i can think of at the mo....
Theo
Post Sat Dec 16, 2006 10:49 pm
If you haven't already done it, soak the exhaust manifold studs/nuts with wd40, the studs are prone to snapping which is a real pain in the arse, especially if the snap flush with the head! Remember to use the correct sequence when undoing headbolts, and it's important to torque them up to the correct value. Oh, and make sure you have the right socket for the head bolts if they are the star type, think it's E14, but it's worth checking that.
kam-325i
Post Sat Dec 16, 2006 11:04 pm
Its defo E14 for the torx head bolts, i've got it in front of me.
Andyboy
Alpina Colada
Post Sun Dec 17, 2006 12:35 am
.....and if it's got oil and water mixing, another cylinder head too.............
seanboy
Post Sun Dec 17, 2006 4:28 am
cheers lads
Brian28
Post Sun Dec 17, 2006 7:37 am
If you are doing it by yourself, leave the inlet manifold on. When putting the head back on again, put the breather pipe in place in the block first, hold the spring coiled up with a cable tie. Also (although I've never bothered to do it) to make getting the head into place on the block a bit easier, cut the torx head off one of the old bolts and screw it in a few threads, you can then drop the head on over this to help everything line up and unscrew it again when the head is in position. When the head is off, check the head bolt holes are clear before putting the head on again.
Brian
Post Sun Dec 17, 2006 10:35 am
Head should really be lightly refaced when it's off.
If it's got any miles on it, then new exhaust valve guides are usually needed, along with some attention to the valve seats.
jcjdavis1
Post Sun Dec 17, 2006 12:35 pm
Hi reading through all these comments is starting to scare me as I am about to get a 320i touring which needs doing. :roll:
Post Sun Dec 17, 2006 1:39 pm
Local engine machine shop does all the work - I just take a head off, remove the cam and rockers and deliver it to them.
They do the skimming, crack testing, guide checking and replacing, valve refacing, valve seat cutting and lapping, and sort out any broken studs or stripped threads.
