re: what ecu works?
rewast
Post Fri Dec 15, 2006 9:33 pm
Right, so I found out yesterday that the ecu has fried because the previous owner, had taken the lid off, and replaced with a plastic bag!
So the question is this, my car is an mtech 1 325 - is this ecu the same as any other 325 including facelift ones?
Thank you guys
Happy Christmas
kam-325i
Post Fri Dec 15, 2006 9:43 pm
Depends on the engine...early or Late 2.5.........
rewast
Post Fri Dec 15, 2006 9:47 pm
Do you know how I find out? Its an e reg/87 - im gonna check the number late on, its broken down a couple of streets away ya see so have a little walk ahead of me
kam-325i
Post Fri Dec 15, 2006 10:02 pm
its easier if you have the last 7 digits of the VIN.
Theo
Post Fri Dec 15, 2006 10:05 pm
If it is an mtech 1 like you say, then it will require an ecu where the last three numbers on the Bosch number are 073.
Later cars use the 173 or 380 ECU's - these won't work.
rewast
Post Sat Dec 16, 2006 6:48 pm
Ok. I had the ecu (under steering wheel and indeed has 073 as the suffix. It had signs of damage and as we delicately opened it up it became clear that a component had become disconnected...gonna try soldering it back in later.
I have been to 2 scrap yards today and it seems very unlikely that I will find another ecu of this type : s
So what is the control unit in the glovebox then?
Thanks for the help guys
kam-325i
Post Sat Dec 16, 2006 6:49 pm
The one behind the glove box is the ABS ECU.
rewast
Post Sat Dec 16, 2006 6:53 pm
A ha!
Cheers dude
