resetting service lights
geo1400
I've tried following the instructions on bimmer DIY but it won't work. Use'd jump wire and nothing happens, what could I be doing wrong?
Cloggy Saint
geo1400
Yeh followed the diagram exactly. When you turn the ignition on is the first turn, or second turn when the ignition llights come on?
Cloggy Saint
geo1400
I'll try again. DIY says if it doesn't work you might have to change the batteries on the SI board...
Cloggy Saint
Ziggy
Definately true I'm afraid... & quite likely what you're up against here! Second position's what you want though, so try that first.
geo1400
ok, i'm an idiot, The diagram on DIY must be for a LHD car cause the 'pac-man' faces the wrong way on mine. Got the right pins and i've only managed to reset the inspection light, the oil service won't go away?
Cloggy Saint
geo1400
Done It!! Thanks guys, I think I just didn't have good enough connection with the wires, only took 3/4 secs.
Thanks again,
Thanks again,
BenE30
where did you find this information buddy??
spence_star
go onto ebay and they sell a little instrument that you plug into your engine somewhere and it resets your service lights they go for like £20
Returned after many years out.
Cloggy Saint
geo1400
best site ever for E30 guys.
http://www.bimmerdiy.com/e30
The wire worked fine, didn't fuse it though...
Second best site, maybe!
