has anyone else had this problem?
my 325 kept cutting out, so I got it checked on the computer and the garage couldn't get a signal from it so they took the cover off the ecu and it was full of water.
the carpet is dry on the drivers side and I haven't seen any water dripping down under the dash.
water in ecu
Do you park the car outside at a perculiar angle? E.g. On a kerb one side, or on a steep hill?
littlejim
it sits on flat ground
odbod
I have water coming from the ECU area and dripping on my feet... I have now spotted that my windscreen leaks at the bottom corners. Going to seal it up ans see if it improves.
