Right a few tings wrong with the car that are starting to get on my tits. Does anyone know how to solve them.
1, firstly abs light comes on randomly, is this just a case of cleaning the sensors or do they need replacing?
2. car didn't get started for 3 weeks, I changed the battery to the BMW one and started first time, awesome! but now ALWAYS idles at 1500 rpm, wether its warm or not.
3. when the car starts there is a shit load of squelling from under the bonnet (only for a few seconds), I assume the power steering belt slipping on start up, can I tighten it or does this also need replacing?
4. Temp gauge won't move from cold regardless of if the heater is blowing ice cold air or hot air, is this the brown on the blue temp sensor? Where do I get a replacement quick/cheap? and the needle does hop about alot (not much movement just very fast short jumps) really really fast too, like a 90's dance kid on acid. is this a related problem?
Thats all folks, any help much appreciated - ta
a few niggling problems
march109
march109
should have also mentioned I'm gonna book her in for a service after the season of bleeding my wallet dry (crimbo) but would rather do the two mins jobs myself to save some dollar. I want ever concievable service part changed since it didn't come with any (recent) history apart from purchase receipts of the replacement parts (which doesn't garauntee they were fitted). What do you reccomend? I'm thinking;
Coolant Change, water pump change, oil change, oil filter change, fuel filter change, cam belt change - anything I missed? or you'd recommend as extras?
Templ8e30
The brown temp sensor is for the gauge, blue one is for the engine management.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
march109
Cheers dude, anyone shed any light on the other issues?
orangecurry
2) if you disconnect the battery for long enough, the E30s very limited brain takes AGES to sort out the fuelling; 100 miles at least, with lots of start/stop/stalling... well, mine does anyway
3) have you checked the PAS fluid level?
don't forget the cambelt pulley/roller/tensioner (whatever you want to call it)
if you go to your local BMW dealership, and say you are in the trade, you will probably get a discount
cambelt B93.24.0.00.006 15% discount = 14.67
roller (pulley) B11.31.1.711.153 10% discount = 39.45
plus VAT of course
get their coolant as well - it is good.
plus VAT of course
march109
2. that would explain it.... I'll worry about it in 100 miles then.
3. nope, but when it gets light again I will (damn winter!)
Cheers for the bmw tip, the guy in there normally sorts me out with discount anyway, fortunatly they all love my e30, even gets admiring glances from the hotty behind the counter at the dealership and it doesn't look out of place in the car park either, shame I do, and don't get the attention the car gets!
Sanchez
the squelling could be the alternator belt as well just make sure its tight enough and not in need of being replaced.
jcjdavis1
Hi when you are at it rocker cover off change spray bar+nuts,bolts(be careful)and gasket clean old oil from cover and any that is lying about.
