Am Hopein someone can help me...the problem is, on my 318is my hazards stopped workin, then a couple of days later so did my indicators...now my brake lights don't work...i hav checked the fuses and they are all fine!
If any1 could help i would really appreciate it...
Light Problems...
If you are sure the fuses are OK, hazard light and indicator problems are usually the hazard light switch. Dismantles easily enough for a clean up and lubrication with a little silicon grease.
Doubt if there's any connection with your brake light fault. Usually the brake light switch at the top of the brake pedal. Pull off the connector and short the two pins together to see if they light.
e30_Zimmer
thanx mate...sorted it all now...thanx 4 ur help tho
