Idling lumpy
win
Post Wed Dec 13, 2006 3:56 pm
I've just given my car a full service i've cleaned out the throttle body and inlet manifold and also the icv but its still not running how i know the straight six should run. I've also changed the manifold gaskit and the car performs well when driving but still seems to idle a bit lumpy, i've also had it tuned and the co mixture adjusted. Any advice on anything else i can try will be welcomed. Its a 325i sport.
Win
eltel
Post Wed Dec 13, 2006 4:58 pm
i had the same problem with my 325.... tried everything and wasted numerous cans of carb cleaner looking for an inlet air leak.... brian moooore suggested the valve clearances.
i did these to 0.25mm and instantly smoothed it out leaving the car sweet and responsive
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
win
Post Thu Dec 14, 2006 8:19 am
Cheers for that, that was the next thing on my agenda as i did'nt know what else to do. Hopefully that should solve the problem
DaveD
E30Zone Wiki Specialist
Post Thu Dec 14, 2006 8:24 am
the Americans recommend checking the o2 sensor as well
win
Post Thu Dec 14, 2006 10:54 am
DaveD wrote:the Americans recommend checking the o2 sensor as well
Mine does'nt have an o2 sensor as it is pre facelift model without a catalytic converter.
Post Thu Dec 14, 2006 10:52 pm
It'll never idle properly if the throttle position switch isn't working properly, and some of the run off from your throttle body cleaning activities could have got into it.
win
Post Fri Dec 15, 2006 8:26 am
hi, where is the throttle position switch located and are they expensive to replace? Also another zoner said you recommended having the valve clearances adjusted will that also help?
DaveD
Post Fri Dec 15, 2006 9:25 am
just a point ...did you put on a new gasket when you put the throttle body back on..........................it's a must
Post Fri Dec 15, 2006 9:30 am
win wrote:hi, where is the throttle position switch located and are they expensive to replace? Also another zoner said you recommended having the valve clearances adjusted will that also help?
See "My E30 keeps stalling" thread.
