the box has quite alot of chatter under load but not at idle - it is quite annoying...
whats the absolute best oil i could use to quiten it? i dont mind if its notchier when cold aslong as the chatter dies down
thanks
how to quiten the gearbox?
Templ8e30
What oil are you using ?
SAE 80W gear oil is standard fill.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
thebigone
sawdust (he he)
liam012
a good mix of bearing nuts bolts and screws by the sound of things...
i'll refill with sae 80w - is that the absolute best?
Templ8e30
You could try diff oil SAE 90W, although cold shifting will be harder
Cheers,
Iain T
Cheers,
Iain T
320Touring
true Iain, tbh either SAE 80W or a new box.Templ8e30 wrote:You could try diff oil SAE 90W, although cold shifting will be harder![]()
Cheers,
Iain T
Anything near frozen with 90W means no gears for at least 10 mins til the car heats up
Ant
- Retired Team Member
I fitted rebuilt boxes that still had the gear chatter, its a design "feature" of the Getrag 260: lol:
If you want to try and make it quieter....... stick some ATF 3 in it, just make sure the seals are OK 1st Liam
Email FTW
