camshaft running in!
Yeti
Post Sun Dec 10, 2006 11:10 pm
Ive got a 316 which the cam is knakered as they usually are, i can change the cam but ive looked in the haynes manual and it doesnt say anything about running the cam in, does any one know what needs to be done to run it in.cheers.
Andyboy
Alpina Colada
Post Sun Dec 10, 2006 11:52 pm
If it's a brand new cam, coat it in either the proper cam lubricant or failing that, EP90 gear oil. Once it's started run it at 1500+ rpm for 15 mins - under no circumstances let it idle. The first 15 mins of a cam's life are crucial.
Templ8e30
Post Mon Dec 11, 2006 11:50 am
Andyboy wrote:If it's a brand new cam, coat it in either the proper cam lubricant or failing that, EP90 gear oil. Once it's started run it at 1500+ rpm for 15 mins - under no circumstances let it idle. The first 15 mins of a cam's life are crucial.
I second that, spot-on.
The friction on the cam lobes at idle are much higher than any other rpm, a new cam hasn't bedded in yet an can 'gall' picking up metal from the rockers and quickly destroying a new cam.
I deally you should use new rockers as well.
I use proper engine assembly lube, it's a thick oil (almost grease) that has Molybdenum Disulphide in it. Most engine recon shops sell it.
Also if it's an M40 engine fit a new spray bar, they block up and cause cam wear.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
