What hoses/pipes shall i replace?
SwirlyE30
Post Tue Mar 29, 2005 11:46 am
Ive got a new ICV on the way, but just incase that isnt whats causing my idle problems, the only other thing i can think of that would cause it would be an air leak somtimes as that seems to explain a lot. Thing is, i cant see off hand any pipes/hoses that are dodgy, is it worth just replacing the lot? If so is there a certain set of hoses that i need to replace that would most likly be causing the problem? ie all the inlet hoses n stuff.
Cheers guys (btw its an m40 1.8i)
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
A1BMW325iSport
Post Tue Mar 29, 2005 4:16 pm
if the hoses look ok, i would have a good check for air lead from inlet manifold.
Davenotouring
Post Tue Mar 29, 2005 4:21 pm
Sam,
Take of the rubber air intake pipe from the airflow meter to the throttle body and give it a bend ( :? ) to see if there are any splits in there.
I've just ordered one from Bmw, which I'm hoping will cure my dodgy idle, and hesitation problem. (It did when it was taped up!)
BMW 328i Cab - Daily Slag
redshanx
Post Tue Mar 29, 2005 11:48 pm
What did Bmw ask for the hose?
I'm curious as mine seems to have a minor issue with the idle aswell!
A1BMW325iSport
Post Tue Mar 29, 2005 11:51 pm
17.42 on my last invoice
redshanx
Post Tue Mar 29, 2005 11:57 pm
surprisingly good!
cheers
Dont suppose u know of any other possible causes & remedies for a fluctuating idle? I'm about to upgrade all the plugs & HT leads, also a new air induction kit which, so I'm told, may help a little.
